Old 09-09-2013, 07:35 PM   #19 (permalink)
racprops
I will.
My 300 HP Car does get 30MPG so it is not too far fetched.
I was disappointed to get such answers, I really thought people here had done more.
The thing is even car makers admit that only 20% of the fuel put into your engine make HP, the rest is wasted, some burn after the power stock some burn on its way out of the engine and what is left is burned by the cat.
Problem is ONLY the gas VAPOR that is made during the compression and power stock is able to make power.
NOW IF you can convert the gas to vapor and only use what is needed for power ( the 20%) what will you get??
A 80% in savings. so 80% X say 30MPG = 150MPG?
Rich
