Originally Posted by Diesel_Dave
Where in the world is your ECU located where it'll get wet it you leave the window open? Every one I've ever seen is under the hood.
Some Audis (mid-2000's A6 for example) have control modules under the seats, you know... the lowest point of the interior. They also have a tendency to leak water into the car with the vents get clogged with leaves. That's a nasty combo.
