Old 09-11-2013, 11:59 PM   #6 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
You can check compression and the timing belt, and it might help you pick up a few more MPGs. But I think cbaber is right. The car seems to be functioning close to normal, except for low compression, which could be significant, I realize. Still, you'll need to become willing to mod it and your driving technique to realize really significant gains. Pumped-up tires, grill blocking, airdams, and especially engine off techniques and acceleration in optimum load ranges are the biggest, cheapest, simplest winners. The amazing thing about the acceleration is how without instrumentation, it is really about impossible to hit the right level of engine load. For your OBD1 car, you'll need a vacuum gauge at least, and preferably an MPGuino and tachometer (in that order of importance).
Good luck. Start a fuel log here. Monitoring the numbers over time is a great way to adapt and adjust technique and mods.
liquidzorch (09-13-2013)
