Old 09-13-2013, 10:45 PM   #5 (permalink)
jeff88
Lots of Questions
Motor-Rolla - '01 Toyota Corolla LE
90 day: 28.3 mpg (US)
Gaia - '99 Toyota 4Runner SR5 Highlander
90 day: 19.78 mpg (US)
Gaia - Round 2 - '99 Toyota 4runner SR5 Highlander
90 day: 17.92 mpg (US)
For this tank, I am working on the tires. About 100 miles into the tank, I gave the tires a boost.
Toyota recommends: 32 Front & Rear
Sidewall max: 40 Front & Rear
PSI before: ~30 all the way around
PSI now: 35 all the way around
We will see how it does to the FE. Handling & ride comfort doesn't seemed to have changed, so if there is a positive change in FE, I'll see what max PSI does.
Don't forget to like our Facebook page!
Best EM Quotes:
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9 View Post
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
