Old 09-14-2013, 12:38 AM   #71 (permalink)
Awd180
wrx - '02 subaru impreza wrx wagon
90 day: 33.81 mpg (US)
Leg - '05 Subaru Legacy 2.5i
That sucks the mold flexed a bit, f/g needs to be done in a controlled environment. Try heat lamps and let it cure for at least 24hrs. I'm not saying access port, a tactrix cable is a third the price, but a subaru specialist could do it and you won't have to worry about finding a good open source tune. A specialist has a better source to tune then you doing it yourself. Basically find a local mechanic that works specifically on Subaru's, a performance tuner will be more expensive because they work on various models.
Just to be clear; a subaru dealer is a good place to start but they can't do it, a subaru speciality shop is a rally shop, a performance tuner knows vetecs better but can do it for a little more.
