Old 09-17-2013, 09:50 PM   #8 (permalink)
MetroMPG
90 day: 51.82 mpg (US)
Originally Posted by Awd180 View Post
Drag coefficients that you read on a chart are computed at ~40-45mph, whereas when you are going slower its lower and faster its higher. You can speculate values but without quanitified test results your values aren't critical and therefore useless.
"Useless" is an overstatement. True, Cd changes with speed but the difference is small enough that for all intents and purposes we can assume it's constant for the speeds at which a road vehicle typically operates. There's a thread around here on this subject with sources cited.
