Originally Posted by AndrzejM
You can try to use diff from e36 Compact 318 tds it's a 2.79:1
The e36 uses a 1:1 5th, whereas the e30 uses a 1:0.87 5th, so that diff would be mighty long.
The 3.73 is a good compromise for lower gear accelleration, and high gear cruising.
Like the thinking though, and good knowledge
