09-18-2013, 04:01 PM
#11 (permalink)
Originally Posted by MetroMPG
You're probably safe to block those side grille sections from the rear -- I'd also look at adding weatherstripping around the edge to seal against the bodywork & headlights when installed. (I take it you'd have to remove that to change a light, so caulking isn't an option?)
I wouldn't rule out a partial Kammback/downswept "spoiler", if you've got the fabrication abilities. OEM ones of varying lengths are becoming commonplace on hatchbacks & estates. EG: Honda van, Mitsubishi Mirage.
Thanks!
They're not as conspicuous as they might have once been.
The bulbs can be easily changed from the engine bay, but I'd like to keep them removable.
I'd toyed with using pipe insulating tape so I get some heat containment as well. Additional engine bay sealing and insulation could be done as well
Those wings look good, I shall investigate
My Blog on cars- Fu'Gutty Cars
http://fuguttycars.wordpress.com/
US MPG for my Renault Clio 182
09-18-2013, 04:05 PM
#12 (permalink)
Originally Posted by AndrzejM
You can try to use diff from e36 Compact 318 tds it's a 2.79:1
The e36 uses a 1:1 5th, whereas the e30 uses a 1:0.87 5th, so that diff would be mighty long.
The 3.73 is a good compromise for lower gear accelleration, and high gear cruising.
Like the thinking though, and good knowledge
09-19-2013, 03:08 AM
#13 (permalink)
I'd love to swap e30 gearbox to Berta. That would give me ~90km/h at the point where turbo kicks in. That would be nice...
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
09-19-2013, 06:46 AM
#14 (permalink)
If your engine has the same bolt pattern on the bellhousing as an e30 318i (m40 engine) I've probably got a box spare
09-19-2013, 06:52 AM
#15 (permalink)
I'd need to check that...
09-19-2013, 07:31 AM
#16 (permalink)
I think your engine is a shortened version of the m51 diesel lump, based on the m50 6cyl petrol.
I know an m50 bolts up to an e30 318i box
do some digging
09-19-2013, 07:40 AM
#17 (permalink)
I know for sure that m41 has the same bolt pattern as m51.
09-20-2013, 03:18 PM
#18 (permalink)
well, if the m51 has the same bolt pattern as the m50, you should be good to use an m40 box on your m41
09-20-2013, 06:17 PM
#19 (permalink)
Old Bimmers are great
Once other nice thing about RWD: how easy it is to change final drive gearing (subject to availability).
RWD has many other advantages, altough they're nowadays pretty much neglected. Nowadays even BMW is going to introduce a FWD model
09-20-2013, 06:46 PM
#20 (permalink)
Damn straight! so much more connected with it than a new car (having run the e36 that replaced the e30 model)
I know- its a disappointment, but I cant fault the business model.
And I don't car what they do with the new stuff if it means hey can afford to keep the oldtimers in genuine parts with a 2 day turnaround from Germany.
Its about 10000x better than the old model support from VW
I may have a look in the DIY stores tomorrow and see if I can get some insulating wrap to make a grill block
