I got my ScanGauge today!
I also got a KN High Flow air filter (went back to the factory air box), 5 quarts of royal purple 10w-30, a royal purple oil filter, royal purple differential oil (2 quarts), spectre differential cover and gasket, 6x ac delco iridium spark plugs, ac delco spark plug wire set, ac delco distributor cap, ac delco rotor, and an ac delco fuel filter.
I popped the air filter in and changed the oil and oil filter today as well as cleaned the MAF and intake sensor with electronics cleaner then reset the computer. Going to (hopefully) do the differential oil friday evening and put on the new cover (do I HAVE to paint it? I like the idea of that shiny silver thing under my blazer even if it only stays shiny for a few days). I'll do the fuel filter after that and then save the plugs and wires for the weekend.
By the way, after I changed the oil/air filter/oil filter/reset computer, the scangauge is reading 21.6 MPG. That's 6 higher than before!
