Old 08-28-2013, 10:33 PM   #11 (permalink)
The brake pedal is evil
Denny's Detector - '08 Mercury Grand Marquis
Taserface - '17 Chevy Volt
I laugh at AC deletes and I live near the coast (some days I can see 2+ degrees per mile temperature rise between the beach and my house.)
Getting sensor data off of a pre OBDII Toyota ECU via TDCL.
All of this is on E10: Project E is my current focus.
Old 08-29-2013, 07:59 AM   #12 (permalink)
Black Knight - '94 Toyota Corolla
90 day: 58.53 mpg (US)
I still have the AC but never use it until the family is in the car. If its just me i keep the four windows cracked about 2-3 inches. set the foot as 55 and let her go.
and i live over on the east side.
Old 09-19-2013, 01:59 AM   #13 (permalink)
The Blazer - '00 Chevy Blazer LT
90 day: 16.31 mpg (US)
I got my ScanGauge today!
I also got a KN High Flow air filter (went back to the factory air box), 5 quarts of royal purple 10w-30, a royal purple oil filter, royal purple differential oil (2 quarts), spectre differential cover and gasket, 6x ac delco iridium spark plugs, ac delco spark plug wire set, ac delco distributor cap, ac delco rotor, and an ac delco fuel filter.
I popped the air filter in and changed the oil and oil filter today as well as cleaned the MAF and intake sensor with electronics cleaner then reset the computer. Going to (hopefully) do the differential oil friday evening and put on the new cover (do I HAVE to paint it? I like the idea of that shiny silver thing under my blazer even if it only stays shiny for a few days). I'll do the fuel filter after that and then save the plugs and wires for the weekend.
By the way, after I changed the oil/air filter/oil filter/reset computer, the scangauge is reading 21.6 MPG. That's 6 higher than before!
