Old 09-21-2013, 06:46 PM   #12 (permalink)
renault_megane_dci
la_voiture_de_courses - '03 Renault Megane Estate
OldContinents
90 day: 44.34 mpg (US)
xiao lan - '01 Audi A2
90 day: 38.88 mpg (US)
Brit iron - '92 Mini Mini
90 day: 45.5 mpg (US)
Prius - '09 Toyota PRIUS Lounge
90 day: 47.37 mpg (US)
Beemer - '06 BMW F800 ST
90 day: 53.06 mpg (US)
It is difficult to regrind a cam for economy if the factory did not studied and manufacture an improved camshaft already because it does require a huge amount of testing.
"Atkinsoning" camshaft is only suitable on twin cam engines.
On non performance engines, it is a high probability that the camshaft is difficult to improve upon.
Maybe a little more exhaust lift and duration to purge the cylinders more efficiently.
Maybe a little less inlet duration at the expense of top end power.
I would not do it unless there is a known alternative timing based on that particular engine ...
