Originally Posted by 320touring
Why do you need the box to kick down? If you do P&G where your lowest speed is at the bottom rev range that 6th will turn, you'll get the hard acceleration in high gear- I did all my P&G in the iS and saab using 5th.
Is shifting to neutral a "pull both paddles and get N" or "move the selector to N"?
Hadn't tried both paddles, will give that a go. I was shifting the lever. I don't worry too much about going into N but going back to D makes me uneasy which means this strategy is being used less than I would like.
that looks like fun! symptoms seem to be poor fuel consumption, and hesitancy when throttle pedal pressed? TBH if you've got some cash tied up in it, its probably worth getting a decent Indy to have a look at it for you?
that sounds odd re the gearbox- you checked the fluid level? My bro's old BMW auto used to do that when the box was low on fluid. no reverse, select 1st, then back to reverse and she's move
The linky including instructions on how to clean various parts, the owner also went for an EGR delete. I'll get the garage to check the fluid level at some point - this week is going to be tricky though.
And Hermann might be off to Audi to have some rust (yes really, rust
) sorted out...
