OP's battery may just have been weak already.
Lead acid is really not a good match for an ICE. They actually require a long slow recharge after a discharge so even without EOC, your battery may be dying:
The electrolyte of a stratified battery concentrates at the bottom, starving the upper half of the cell. Acid stratification occurs if the battery dwells at low charge (below 80 percent), never receives a full charge and has shallow discharges. Driving a car for short distances with power-robbing accessories contributes to acid stratification because the alternator cannot always apply a saturated charge. Large luxury cars are especially prone to acid stratification. This is not a battery defect per se but the result of use.
From the
battery university
Every car should have a solar tender in them or be trickle charged at home to prevent Premature battery death.
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
