Xist, thanks for overlay, the curve is definately more agressive then original template, I was thinking it is much closer to the new version below with the steeper angles at the start.
3 Wheeler, I manipulated both constants until I got exactly 2.5 aspect ratio and 1.78 tail ratio, to get this M = 1.4754408 and l/w = 1.9130000020752, the original values for the constants of 1 & 1.925 gave a tail ratio of 1.67 and yes is still increasing angle at end of tail, but does not fit template that well either.
I like this equation and will fiddle a bit more and try out different combinations, I can get a closer version with less kink in tail, but the aspect ratio is around 2.54 with a 1.78 tail ratio, so there are plenty of options to choose, later tonight I will try put up a version where the tail reaches max curvature without changing direction.
Originally Posted by betasniper
Yeah, It was about a 15° angle at the end for that one because the thickness was only 35% (Eppler 863). I posted that airfoil because that was the largest symmetric airfoil I found in that database. There is a very slightly unsymmetric airfoil which is a 38.8% thickness (Eppler 864), but even that one only goes to an 18° angle.
I put the AST-2 Template into Solidworks and tried as best as I could to make a simple spline fit the Template but These are the angles I got:
Largest deviation (angle wise) was the very first angle with a 1.3° discrepancy. Everything else is within .4°. The grey dimensions are driven and Σ's are equations. Only the black Numbers without Σ can be altered (The 500 and the 23°). The blue lines above the spline represent the curvature. Bigger lines means more curve, Smaller lines means flatter.
Edit: Even though the angle discrepancy is large, the spline I drew was slightly slower curve than the template. Very slight.
Code:
Percentage | 0% | 10% | 20% | 30% | 40% | 50% | 60% | 70% | 80% | 90% | 100% |
X | 0 | 172 | 344 | 516 | 688 | 860 | 1032 | 1204 | 1376 | 1548 | 1720 |
Y | 500.00 | 488.92 | 461.69 | 423.61 | 377.54 | 325.23 | 267.81 | 206.09 | 140.62 | 71.81 | 0 |
Angle | 0° | 6.8° | 10.9° | 13.9° | 16.0° | 17.7° | 19.1° | 20.3° | 21.3° | 22.2° | 23.0° |
