Old 09-23-2013, 07:12 PM   #101 (permalink)
TurnNBurn
Originally Posted by mechman600 View Post
Probably not a big deal being on the unloaded side of the chain. Ryland's suggestion is good. Even a simple plastic guide would be good enough on the unloaded side, the same as most motorcycles use along the top of the swing arm to guide the chain during decel.
Nice build!
I don't know if I would feel comfortable with the chain sawing away at the plastic and then the swing arm. I'd be paranoid it would cut through. I don't think the picture does it justice, but it's not a little rubbing. It's actually resting a lot on that arm. It doesn't look good.
Thanks for the compliments. I'll have to get the higher res copies up soon. They have better lighting.
