Oh, cool that makes total sense, didn't think about that. Thanks! Do you think that if one were to use ethanol (along with any supporting mods) with a VVT engine, one could increase torque to increase city MPG?
I assume by maxing out your injectors you mean the fuel pressure needed? Could you upgrade your fuel pump/injectors to allow for the higher pressure?
Don't forget to like our Facebook page!
Best EM Quotes:
Originally Posted by aerohead
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
