Old 09-26-2013, 04:07 AM   #11 (permalink)
alvaro84
alvaro84's Avatar
Teresa - '04 BMW F650CS
Motorcycle
90 day: 80.53 mpg (US)
The YARDIS - '99 Toyota Yaris 1.0
90 day: 59.52 mpg (US)
According to our experience, even a little bit taller gearing (14T->15T front sprocket) can help pretty much, while the effect of removing 20lbs is almost negligible. A whole 150-lb passenger with all the aerodynamic and weight effect can change FE by at most 10% - what do you expect from an almost invisible (frontal area-wise, hidden under riding jacket&pants) 20 lb?
Gearing (and the effect of its change) is model dependent, of course. There are ecomodded 250s with insanely tall ratios - our Ciliegia isn't like that. And Teresa runs w/ stock gearing (belt drive).
Other than that, exercising can really help.
