It may not be the advice you're looking for....
But I agree with Insight: if you're considering spending that amount of money on some of the mods on your list, I would instead start watching for a more efficient car.
But to your list:
Power Steering Delete- Not sure how much this is going to cost.
I don't think you'll find a shop willing to do this for you. And the Camry has
very heavy steering minus assist. (I wouldn't drive one without it for convenience/safety reasons.)
New Hi-flow Cat- Around $600.
Modern exhaust- $300- $900 I reckon.
Neither will help your mileage. At the low RPM eco-drivers tend to operate their engines, your factory exhaust has enough capacity.
Manual transmission swap- Around $2500 (yikes), car was never offered with a Manual transmission which is why the swap is more expensive than normal.
A manual is one of the best things you could have to improve milage (particularly urban), but $2500 is getting into the range where you can find a different 4-cyl manual car!
AC Delete- I hardly use it at all so it's mostly just dead weight.
Can't argue with removing dead weight. But its impact is relatively small, pound for pound. So if you're paying someone to do the work, you'll likely not see a reasonable return on investment.
