I'm going to clean up my cooling system. Right now (not sure if stock) the radiator can't get any static pressure because there is a gap between my AC condenser and the radiator that looks like there should be ductwork covering. I will likely end up adding more ductwork so that I can have more airflow turn into pressure for the radiator.
