As the amount of heat trapped and radiated depends on temperature, it is affected by how heat is moved around within the atmosphere, oceans and across the Earth's surface, and by altitude. You can't use averages.
I prefer to simply trust the professionals.
In terms of action, I think this guy has it correct:
http://paulgilding.com/cockatoo-chro...le-begins.html
