Making slow progress on grill block v3.1 because I only have 2 hours a day to work on it.
Fiberglass has set...it's a little uneven as the resin gets absorbed by the great foam. Good thing is that the Great foam has not shrunk yet
Bondo
Guide coat to help make the bondo as even as possible
next up this weekend: Sanding, bondo, sanding, bondo...hopefully paint.
