Old 09-28-2013, 02:11 AM   #96 (permalink)
Xist
Originally Posted by jedi_sol View Post
Yes i tried that!
The TOP of the fiberglass came out smooth, however, because the greatfoam absorbed the resin unevenly, the bottom became uneven.
so i've got smooth and uneven fiberglass. oh well
at least i only had to use a thin layer of bondo, so sanding shouldnt be that bad.
Did the 'Stuff absorb the resin, or did the resin melt the foam?
Is there a difference?
I guess that I cannot say that I have not done anything, I went through one can, but I am going to study instead of continuing the process.
No, really! I mean it this time!
I did a quick search because I remembered that there were different types of resin and foam and that some work together and others do not. I remember someone putting resin on his foam and it melted the outside a quarter-inch or so. Anyway, have you read this? http://ecomodder.com/forum/showthrea...oam-21668.html
