Old 09-30-2013, 05:41 PM   #5 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
I bent some aluminum sheet to be attached to the factory fender liner mounts on the fender liner end and use speed nuts on the other for the fender skirt, but that is as far as I got. My plan was to have several mounting points for the fender skirt to screw into so only the screw head would show on the outside. I got stuck trying to decide what material to make them out of. Post a photo if you get something that works on a VW and doesn't damage the paint.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
