Originally Posted by Arragonis
My point is that the SG2 is pulling the data from the OBD port at regular intervals, so if you acclerate fast and it has fewer data points to average from, accelerate slowly and it can more or less log every change and be more accurate.
Confirmed by Linear Logic just now:
The RATE adjustment is both for the ScanGauge display update, and the sampling rate.
Accelerating slower would give a more accurate average based on having more data points to compute the average with.
Also note: RATE is user-configurable to update "Fast" about every half second, compared to "Normal" about once per second. "Normal" is the default rate, and it resets to that every time the SG goes to sleep (on my release).
