Xist, what do you mean compare the tires to the template? Are you talking about the lack of levelness between the front and rear tire? I can see that the bottom of the front tire and the template match up, whereas the rear wheel is lower than the template. I'll have to check to see if I have a photo program that can rotate it a matter of degrees, not 90* or 180* only.
I'm kinda excited about doing the kamm with the spoiler attachments. I'm thinking about using an aluminum strip as the main mount. I am considering using a plastic strip from TAP plastics as well. Anybody have any suggestions?
Don't forget to like our Facebook page!
Best EM Quotes:
Originally Posted by aerohead
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
