Old 10-05-2013, 02:59 AM   #33 (permalink)
jeff88
Lots of Questions
Motor-Rolla - '01 Toyota Corolla LE
90 day: 28.3 mpg (US)
Gaia - '99 Toyota 4Runner SR5 Highlander
90 day: 19.78 mpg (US)
Gaia - Round 2 - '99 Toyota 4runner SR5 Highlander
90 day: 17.92 mpg (US)
set it up like this?
<car picture><mpg signature>
Daox, I tried doing it this way, but I can't seem to figure out how to get it right. I uploaded the two pics to Photobucket and then used the images code to put them in the sig, one on top of the other (like a thread post). When I tried to add the second pic, I got an error code for 500 max characters, because the code was kind of long. I switched the code around to switch the pic on top and bottom and it worked within the character movement (know idea...). Then I added in one of the two fuel logs (I had deleted one temporarily for some reason). Now it's saying:
You have included 5 images in your message. You are limited to using 4 images so please go back and correct the problem and then continue again.
Images include use of smilies, the BB code [img] tag and HTML <img> tags. The use of these is all subject to them being enabled by the administrator.
Your signature cannot be longer than 1000 characters including BB code markup.
From what I can tell, I have two pics and two fuel logs (considered pics) and 2 quotes, so I have the 4 max, not 5+. If I don't include the quotes, it seems to work, as if quotes are considered pics. I also can't get the pic and log next to each other like you suggest, I think it's just all too big to fit into the signature.
Originally Posted by ps2fixer View Post
I think the images are too wide to do that, I'm not aware of a "mini" version for the image.
I tried messing around with the size of the log image. The only thing I could find online is two types of coding:
Code:
[IMG=500x100]
Code:
[IMG width="500" height="100"]
Neither one works to change the image size, it just displays the code, rather than the pic.
Don't forget to like our Facebook page!
Best EM Quotes:
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9 View Post
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
