With the cooler flow at the bottom of the radiator, does it make sense to have the grill block lower and have venting inside of the bumper force air upwards towards the higher temperaturs coolant?
I've read most people prefer to block the upper portion of the grill more than lower, but I would think that would hurt cooling and if you do the lower, you can actually block more.
Don't forget to like our Facebook page!
Best EM Quotes:
Originally Posted by aerohead
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
