Old 10-08-2013, 02:14 AM   #37 (permalink)
mechman600
mechman600's Avatar
Fusion - '16 Ford Fusion Hybrid SE
Originally Posted by jeff88 View Post
Everyone has, at one point or another, started their car, forgot they started it already and then turned the key again. If there is anybody around, it's one of the most embarrassing things to do. But what causes the horrific screeching sound?
Normally when you start the engine, the ring gear (attached to the crankshaft) is stopped. The starter gear pushes/engages into it and then starts spinning to turn it.
When the engine is running, the ring gear is spinning. If you hit the starter, the starter gear gets pushed into an already spinning ring gear.
Sort of like poking your finger into a spinning fan. You would be screeching too!
