10-03-2013, 09:47 PM
#31 (permalink)
Originally Posted by Occasionally6
I think Toyota's use a proprietary coolant from the factory. It's not compatible with some other coolants so flush well before swapping in something else. If you don't, you can get a mud like sediment in the cooling system if the old and new coolants react.
I've already seen some folks getting in trouble with Toyotas for that matter.
10-04-2013, 12:09 AM
#32 (permalink)
Originally Posted by bestclimb
I offer a very hearty thank you FAA for their support of general aviation technological stagna...advancement.
Well, I can understand it up to a point. After all, you can't just pull over to the side of the road if your airplane engine conks out.
....But yeah, the certification process does tend to stifle innovation. Badly.
-soD
10-04-2013, 02:26 AM
#33 (permalink)
Smeghead
In 5 years and 600 hours of piston single time I have had 2 certified ignitions fail. Aircraft typically have 2 magnetos for performance, (because they suck) and for redundancy, (because they suck in a second more serious way).
In 18 years and who knows how many hours/miles (in < 1 year I have driven 20000 miles at a educated guess averaging 35mph for a total of 570 hours) I have had 1 electronic ignition fail that caused the engine to quit.
Most of the noncertified electronic ignition systems I have seen are dual redundant systems as well, because once in a great while one could, possibly, eventually fail...maybe. And as you say you can't just pull over when the engine stops.
I'll just stop here because it's o.t. and I could write a 5 page paper on virtues of various noncertified systems and the FAA's bureaucratic obstructionism and it's cost to the industry.
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
10-04-2013, 03:00 AM
#34 (permalink)
Lots of Questions
Here, maybe this will help:
Hahaha
Don't forget to like our Facebook page!
Best EM Quotes:
Originally Posted by aerohead
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
10-04-2013, 04:36 PM
#35 (permalink)
Smeghead
Hahaha
perhaps a bit
10-08-2013, 01:09 AM
#36 (permalink)
Lots of Questions
Everyone has, at one point or another, started their car, forgot they started it already and then turned the key again. If there is anybody around, it's one of the most embarrassing things to do. But what causes the horrific screeching sound?
Best EM Quotes:
10-08-2013, 01:14 AM
#37 (permalink)
Fusion - '16 Ford Fusion Hybrid SE
Normally when you start the engine, the ring gear (attached to the crankshaft) is stopped. The starter gear pushes/engages into it and then starts spinning to turn it.
When the engine is running, the ring gear is spinning. If you hit the starter, the starter gear gets pushed into an already spinning ring gear.
Sort of like poking your finger into a spinning fan. You would be screeching too!
10-08-2013, 01:16 AM
#38 (permalink)
Smeghead
That is the sound ones pride makes as it is violently stripped from your ego, it sounds exactly like a starter gear contacting the already spinning flywheel.
10-08-2013, 01:21 AM
#39 (permalink)
Lots of Questions
@mechman, thank you! So on cars that have a starter-generator, does a driver have that same problem?
@bestclimb, haha! I can definitely feel my pride being forcibly taken away from me.
Best EM Quotes:
10-08-2013, 01:32 AM
#40 (permalink)
Smeghead
@mechman, thank you! So on cars that have a starter-generator, does a driver have that same problem?.
I would not think so, the gears of starter generators I have been around are always engaged.
