Gotcha. Follow the pin diagram you posted as a template for the other plugs. For example on the 4 pin plug MALE side, top left is 1, top right 2, bottom left 3, and so on. For the FEMALE side simply flip the numbers horizontally. Same thing on the 8 pin plug, but with more numbers. This is assuming that the latch is considered the top of each plug.
