Old 10-09-2013, 03:57 PM   #1 (permalink)
New Here needing help
Hello,
This forum has been very good to me. Usually I can fiquire out what is being suggested. I joined to get additional help. I have been looking a long time for a 94-95 Civic VX and as being in Calf. I was stuck with the Calf. car mainly and after looking at many and rejecting them I decided it would be to costly to go out of state to find one. I finally got a CA. 1993 Vx and have using the suggestions on getting the best MPG so I cleaned stuff out, raised tire pressure and bought a set of Osidetiger's Custom Fuel Injectors. I'm up to 40 mpg city.
So now I'm ready to proceed to NachtRitter's excellent article on converting my car to a Fed one. I just ordered from Ebay a NGK NTK # 24300 L2H2 L1H1 5-wire Wideband Oxygen Sensor for $139 and I'm bidding on a computer. But my reason for joining is that I need help finding the pin locations for the civic 4 and 8 pin wiring harness plugs. NachtRitter displayed the 6 pin one. I would like to find the pictures of these pins so I can start wiring the harness. Converting Cali Civic VX to Fed (lean burn) VX, is the forum title.
I know this isn't the place to continue NachtRitter's topic so I will post there also.
I would of bought the scan gauge from this forum but it won't work on my 93. If I get 50 mpg on the freeway I will get more serious and get some sort of mpg monitor. If not I will sell it and find a VX that will.
If I can add anything I will but everyone that has left repair and modify stuff is beyond me so I doubt I can add much.
Again thanks to everyone that has contributed to the forums it has helped me immensely.
Good Day
Old 10-09-2013, 04:44 PM   #2 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
welcome!!
pump up the psi to 40+
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 10-09-2013, 05:14 PM   #3 (permalink)
90 day: 70.75 mpg (US)
90 day: 62.14 mpg (US)
40 MPG city is quite decent. Is this where you do the bulk of your driving? The reason I ask: lean burn helps most on stretches of open road.
Welcome to the forum!
Old 10-09-2013, 05:30 PM   #4 (permalink)
City now
Thanks for the welcome
I do most my driving city but once this VX gets where I want it I will be doing a lot of long distance driving. I have no problem sleeping on the VX's seats. I don't like spending a lot of money just to sleep in motels. Truck stops or friends for showers. That's one reason I bought it.
Old 10-09-2013, 05:37 PM   #5 (permalink)
Sounds perfect - a VX with lean burn and some aero mods is hard to beat on the open road.
Old 10-09-2013, 06:37 PM   #6 (permalink)
cbaber's Avatar
Lean and Mean - '98 Honda Civic HX
90 day: 46.69 mpg (US)
Are you needing the pinout for the P07 Fed VX ECU? I'm not sure what you mean by the civic 4 and 6 pin.
1998 Honda Civic HX - My Project Thread
Old 10-09-2013, 07:02 PM   #7 (permalink)
If you look at "Converting Cali Civic VX to Fed (lean burn) VX" thread the wire harness NachtRitter makes uses the wiring harness plugs to make a o2 bypass and cpu connection.
Here is the 6 pin plug layout from that thread
bummer I can't post pic till I have 5 posts
Old 10-09-2013, 07:02 PM   #8 (permalink)
Test post to get 5 posts
Old 10-09-2013, 07:03 PM   #9 (permalink)
Here is the 6 pin plug. I meant I needed the 4 and 8 pin plug diagrams
Old 10-09-2013, 09:35 PM   #10 (permalink)
cbaber's Avatar
Gotcha. Follow the pin diagram you posted as a template for the other plugs. For example on the 4 pin plug MALE side, top left is 1, top right 2, bottom left 3, and so on. For the FEMALE side simply flip the numbers horizontally. Same thing on the 8 pin plug, but with more numbers. This is assuming that the latch is considered the top of each plug.
