Old 10-10-2013, 11:27 AM   #3 (permalink)
slownugly
Burn lean and prosper\\//
VLX - '93 Honda Civic VLX
90 day: 51.1 mpg (US)
do you mean the honda plugs that he wired for the jumper harness? or do you need a diagram of the ecu pins? theres no real cut and dry way of wiring the harness plugs up. heck you dont even have to use honda connectors it just makes it look a heck of alot cleaner. as long as you have the right wires going to the right wires. the only honda connector that needs to be honda is the connector that the o2 directly plugs into.
do you have a fax machine? i could fax you the federal factory wiring diagram for whatever year vx you would like.
Burn lean and prosper \\ //
