Old 10-13-2013, 09:36 AM   #35 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
There has got be something wrong with the sensor itself, the wiring, harness, or connections. That's specifically a heated sensor 0 2 Code. A clogged cat would be bad too, but if the code has appeared and you can't clear, I have to think the sensor itself or its connections is the top suspect. Have you investigated the pinout?
slownugly (10-13-2013)
