Old 10-13-2013, 07:10 PM   #2 (permalink)
jeff88
Lots of Questions
Motor-Rolla - '01 Toyota Corolla LE
90 day: 28.3 mpg (US)
Gaia - '99 Toyota 4Runner SR5 Highlander
90 day: 19.78 mpg (US)
Gaia - Round 2 - '99 Toyota 4runner SR5 Highlander
90 day: 17.92 mpg (US)
That is an interesting paper. It makes sense, just good to see it in one cohesive argument. Is there a way to determine the efficiency of your current alternator? I assume you can use a multimeter for the output, but how do you determine the amount of energy going into it?
I wonder if one wanted to have a more efficient alternator at a higher RPM, what would need to be done to make that work. More/heavier coils, lighter stator, domething else?
Don't forget to like our Facebook page!
Best EM Quotes:
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9 View Post
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
