Old 10-13-2013, 10:58 PM   #2 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
That sounds very thorough and I think it will certainly hold shape in motion and flex when it nails stuff like speed bumps. Mine is MUCH less aggressive in attachment. I drilled holes about as you have, but without brakets of any kind. I used screws for most of the holes, except one, in front of the front tow hook, which is on the driver side. On that end mounting point I used two strips of plastic insulated wire twist tie (so I can remove it easily in a towing situation). Not ideal, but convenient and it works. Yours is better, but harder to reverse on demand.
Looks good to me.
TexasCotton (10-14-2013)
