Originally Posted by California98Civic
Since oil leaking slowly from engine and getting onto parts of the undercarriage has delayed the under tray project, I decided to do the wheel skirts before all the long days are gone. Here are some pics of the progress I made in the last light after work today. I am imitating MetroMPG's copper pipe clip idea, and I am using as much recycled materials as possible.
The coroplast is leftover from my first wheel skirt project. The screws and bolts are from stuff I dismantled, including aluminum screws from the 1950s patio shade I took apart a couple years ago. The aluminum bars for the supports were laying around the garage, leftover from a project. Cutting them to fit was a PITA. I discovered that bolt cutters can make great metal cutters in a pinch, when the snips are just not even close to competent.
Job complete enough to drive it, though I think I will add one more clip per side (for four total on each side) and I still plan to cover over the whole assembly with aluminum sheet and paint it and shade of black closer to the car paint color.
AND HERE IS THE LOOK (at this stage):
I am also planning this .....You used copper pipe and formed to make the fender clips? What is the pipe for in the first image?
