Old 05-16-2008, 01:15 AM   #11 (permalink)
Veggiedynamics
Extreme CRX-HF - '87 CRX custom areo
90 day: 50.8 mpg (US)
After this season, I've been thinking of moving to a warmer climate for mental health reasons.
Yeah me too.. Actually i recently bought land in Texas.. rarely gets below 32 degrees..
Old 05-17-2008, 12:09 AM   #12 (permalink)
Recycling Nazi
Bror Jace's Avatar
Blue Bullet - '06 Civic Sedan LX
90 day: 35.68 mpg (US)
I have a late model car ('06 Civic) and I just can't see me putting anything on this car that I made myself.
I'm waiting for a quality-made kit I can buy that has:
1) 2 rear wheel skirts (preferably painted to match)
2) solid wheel covers (at least 2 for the front)
3) a better / lower front splitter (the rubber piece that goes under the front bumper.
The DIYer part comes in when I fasten the bits on.
--- Bror Jace
Old 06-21-2008, 10:31 PM   #13 (permalink)
Blackfly - '98 Metro
90 day: 78.84 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 106.27 mpg (US)
I just finished Rear Wheel Skirts v. 1.5
Skirts have coroplast backing for added stiffness (think I mentioned that somewhere up the thread already).
And they're now attached to the wheel arch with 5 home made brackets that were installed without drilling into metal. The skirts can be removed/reinstalled in about 30 seconds. The downside is there are now 5 screw heads around the rim of the skirt - which don't look too bad.
I'll post new pics tomorrow.
Old 06-22-2008, 08:00 PM   #14 (permalink)
Pics, pics, pics:
First of all, here's the back of the skirt with the coroplast attached (contact/rubber cement) to stiffen it more for those hot summer days (when the black plastic was getting pretty soft & wobbly):
Next, on to the new non-drilling-the-car attachment method. A crummy shot of the DIY bracket. It's made from flattened copper pipe, stainless nut, bolt & washers:
Next, the same bracket, shown installed. Another crummy shot - sorry:
I made 6 of those special brackets in total, 3 per side. Once tightened, they're well clamped down and very solid.
The other two brackets per side attach to the lip of the plastic bumper, so I just made simple 90 degree bends in the copper pipe, drilled & bolted them on:
And here's the skirt installed. I'll probably paint the screw heads black:
Old 06-22-2008, 08:08 PM   #15 (permalink)
YES, those are mud flaps on the back wheels. (*hangsheadinshame*)
They serve as a mounting point for the aft end of the skirts (without them the curvature to bring them all the way to the bumper would be so much that I believe flow would detach anyway).
I'll probably trim the excess off now that the final skirt installation is done.
Old 06-24-2008, 09:39 AM   #16 (permalink)
Old Retired R&D Dude
Transporter - '09 Escape XLS
Did you trim off those flaps?
I took my rear flaps down to my shop so I could use the belt sander to clean off the edges I cut with a Stanly knife.
http://ecomodder.com/forum/36034-post25.html
I think they are going to be a good mounting point, if I ever decide my CRV should be wearing skirts.
Cheers,
Rich
Old 11-25-2008, 11:52 PM   #17 (permalink)
TacoModder
akashic's Avatar
rik's prerunner - '03 Tacoma Prerunner Double Cab TRD 4A
90 day: 29.68 mpg (US)
I really like the copper clips you made. Does that type of clip have a name? Can you buy clips like that anywhere? My tools are not cooperating with me right now, and I could really use clips like that!
So you smashed a copper pipe? Is that 1/2"? How did you drill the holes in it? (I mean what kind of bit?) I tried using copper pipe straps, but it was a lot of work, and they weren't tough enough to hold anything.
Old 11-26-2008, 10:37 AM   #18 (permalink)
Not sure if there's a name, or if you can buy them.
Yes, I flattened a 1/2 inch copper pipe with a hammer and drilled it with a regular bit (copper is pretty soft).
Old 11-26-2008, 10:41 AM   #19 (permalink)
PS - aside from the exposed screw heads offending some people's aesthetic sensibilities, the clips are great. I had the car rust treated earlier this month, and the skirts come off / go back on in less than a minute with this setup.
Old 11-26-2008, 10:59 AM   #20 (permalink)
Toothbrush Special - '96 Aspire
90 day: 43.3 mpg (US)
Did you see much of a diffrence in MPG? By that I mean not a 10 or 15 mile trip, I mean a 200 mile tankfull compared to a 200 mile tankfull?
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.3.2
