Old 10-14-2013, 01:34 PM   #5 (permalink)
jeff88
Lots of Questions
Motor-Rolla - '01 Toyota Corolla LE
90 day: 28.3 mpg (US)
Gaia - '99 Toyota 4Runner SR5 Highlander
90 day: 19.78 mpg (US)
Gaia - Round 2 - '99 Toyota 4runner SR5 Highlander
90 day: 17.92 mpg (US)
Is there a way to do a pulley clutch? Like an A/C or hydraulic fan, but instead of the clutch forcing it off of the drive belt, it would just change over to a different size pully. Then at idle speeds, you can have 2:1 or 3:1and at higher speeds it will "clutch" to 1:1.
I guess that wouldn't really possible, since it would change the size of the belt needed to function properly.
Don't forget to like our Facebook page!
Best EM Quotes:
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9 View Post
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
