Old 10-14-2013, 02:44 PM   #8 (permalink)
jeff88
Lots of Questions
Motor-Rolla - '01 Toyota Corolla LE
90 day: 28.3 mpg (US)
Gaia - '99 Toyota 4Runner SR5 Highlander
90 day: 19.78 mpg (US)
Gaia - Round 2 - '99 Toyota 4runner SR5 Highlander
90 day: 17.92 mpg (US)
Originally Posted by mort View Post
It looks like, according to this graph, the alternator is not even producing current until around 1200 RPM. So what is happening during idle? Does the efficiency go down because it has to convert high voltage down to 14 volts?
Can anybody answer my original questions: how to determine your alternator's efficiency and how to make an alternator more efficient at a higher speed?
Don't forget to like our Facebook page!
Best EM Quotes:
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9 View Post
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
