Old 10-14-2013, 11:19 PM   #40 (permalink)
jeff88
Lots of Questions
Motor-Rolla - '01 Toyota Corolla LE
90 day: 28.3 mpg (US)
Gaia - '99 Toyota 4Runner SR5 Highlander
90 day: 19.78 mpg (US)
Gaia - Round 2 - '99 Toyota 4runner SR5 Highlander
90 day: 17.92 mpg (US)
So I messed with the photos and got it to *mostly* work. My 4Runner pic works perfectly. I cut off some excess on the side which made the overall length a little smaller and so the pic and MPG image are on the same line.
I got the Corolla to do the same thing, side by side, but I can't seem to get the Corolla pic to be the same size. If I make it smaller, it makes it too small and if I increase the size in Photobucket or my photo editing software, it doesn't load as a bigger image, it stays the same small size. I put another pic in with a lot of extra space, but it's still smaller. I will try taking a pic of the Corolla in the same spot as the 4Runner at the same-ish distance and see if I can crop and size it to work.
Almost there...
EDIT: So after this response, I saw that my 4Runner pic and MPG image are not on the same line. I checked the preview for editing your sig pic and it has it correct, but no in primetime, it is wrong. The Corolla is fine though. Maybe I need to retake a pic of the 4Runner and make it smaller to work correctly.
Don't forget to like our Facebook page!
Best EM Quotes:
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9 View Post
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
