Shopping for some synthetic gear oil, for the trans and rear end.
The gearbox is a bit "notchy" when cold, and the rear end howls when it is above 50mph.
Also need some tie rod ends, and bushings all around, looking for poly, like Energy. Something about 30year old rubber. Need struts(front) and shocks (rear). The clutch is old, probably original, weak and overheats easily.
Then possibly a manual steering rack, battery relocation,to the passenger side behind the seat.
Other suggestions welcome
