Old 10-15-2013, 10:14 PM   #53 (permalink)
HyperMileQC
HyperMileQC's Avatar
Trollinsight (Retired) - '00 Honda Insight
Gen-1 Insights
90 day: 68.06 mpg (US)
Redsight - '01 Honda Insight
Gen-1 Insights
Carole - '05 Toyota Corolla Xrs
Brise-Fer - '05 Toyota Echo
Send a message via MSN to HyperMileQC
Lean burn is a special mode the engine goes when there is low load on the engine. The air to fuel ratio goes from 14.7:1 to 20:1 and more sometimes. You burn lean so you take less gas.
But because of the higher emission of Nox due to higher internal combustion temperature, the insight is equipped with a special catalysor to purge the Nox. This is why when you are in lean burn sometimes the mpg drop and the engine suddendly gained more power for 10-30 seconds and then it return to lean burn operation and the mpg increase but you loose power.
Trollinsight Modding Thread
2000 Honda Insight MT Silverstone Metallic #95 (CAN) 131K mi. 81.7 Lmpg
Best Tank : 100.06 MPG (US) | 120.2 MPG (Imp) | 2.35 L/100Km | 42.54 Km/L
Best commute : 130.8 MPG (US) | 157.1 MPG (Imp) | 1.8 L/100Km | 54.84 Km/L
Best Trip : 111.8 MPG (US) | 134.3 MPG (Imp) | 2.1 L/100Km | 47.53 Km/L
The Following User Says Thank You to HyperMileQC For This Useful Post:
tpotts (10-16-2013)
