Originally Posted by WindyDrew
Best tank so far is 65.4. I have to drive over almost every hill in Kansas to get to work  I drive 60 miles each way, either way is usually a head wind one direction and tail wind the other way. Sometimes I luck out with tail both ways and then I get days with head winds both ways. Thank goodness for the ima, I don't think a Geo Metro would survive this drive every day! I've deleted both mirrors and blocked the bottom part of the grill completely. Also run my tires at 50 psi. Getting the tps mod and Imac&c next to hit my temporary target of 75 mpg tank!
Two questions: 1) what is ima (not in Glossary)? and 2) what is the tps mod you are talking about? I'm looking for something that will hold tps (SGII), not speed. Long ago there was an add-on magnetic throttle holder that worked like a charm, but is no longer made.
Joggernot
