Old 10-16-2013, 07:05 PM   #203 (permalink)
josemapiro
Originally Posted by t vago View Post
That diagram looks correct. Do you have access to an oscilloscope? Or maybe even just connect an LED to the PE4+PE5 connection, and see what it does.
Oscilloscope does not have an LED can try, I went to get the signal from the VSS and injector, the ECU is there any difference in that?
Thank you
José Rodrigues
