Old 10-16-2013, 07:23 PM   #5 (permalink)
jeff88
Lots of Questions
Motor-Rolla - '01 Toyota Corolla LE
90 day: 28.3 mpg (US)
Gaia - '99 Toyota 4Runner SR5 Highlander
90 day: 19.78 mpg (US)
Gaia - Round 2 - '99 Toyota 4runner SR5 Highlander
90 day: 18.22 mpg (US)
I'd say 21 days is well worth the wait. It looks like you put a lot of effort into this.
Just want to ask about airflow. Under the hood and above the new grill block is a small slit. Does that allow airflow through the radiator, or that blocked further back? Does the scoop allow airflow into the top of the engine compartment? On my 4Runner, the scoop is blocked inside, which doesn't allow airflow (for anything, let alone cooling). What about underneath the air dam? Does the radiator go down far enough to allow the air that does end up under the car to run through it? Do you have a belly pan to stop that flow?
I'm just wondering if there is any airflow anywhere in the system.
Very nice work!
Don't forget to like our Facebook page!
Best EM Quotes:
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9 View Post
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
