Old 10-17-2013, 04:04 PM   #4 (permalink)
jedi_sol
jedi_sol's Avatar
2013 STi *SOLD* - '13 Subaru Impreza WRX STi
Subaru
Sports Cars
Team Turbocharged!
90 day: 26.59 mpg (US)
1996 Geo Metro *RETIRED from Ecomodding* - '96 Geo Metro Base
90 day: 58.68 mpg (US)
Originally Posted by RedDevil View Post
Second that.
My Insight will shut the engine off when stopped (Auto-Stop) but restarts within 20 seconds or so, where it should last much longer.
I used to key off at the lights to prolong the autostop.
My new UG now shows the real reason why the engine restarts: the voltage drops below 11.6 volt, and continues to drop if I keep the engine off for too long (with lights and radio on)...
I 3rd that. A general rule of thumb with battery voltages (car is completely off with no load on the battery at all):
Full charge 100% is 12.7volts
90% is 12.6volts
80% is 12.5volts
70% is 12.4volts
60% is 12.3volts
50% is 12.2volts
40% is 12.1volts
30% is 12.0volts
20% is 11.9volts
10% is 11.8volts
0% is 11.7volts
Check your battery voltages with a volt meter with the engine off to see where the battery voltage is at.
This is also why if you us heavy p&g...you should also switch your battery out with a deep cycle battery
See the rest of the Sti project log:
http://ecomodder.com/forum/showthrea...log-26612.html
