Old 10-17-2013, 05:22 PM   #12 (permalink)
darcane
darcane's Avatar
Originally Posted by jedi_sol View Post
Check your battery voltages with a volt meter with the engine off to see where the battery voltage is at.
This would be a challenge, it is only an issue while driving and if I stop, I won't be able to start it with the key...
This is also why if you us heavy p&g...you should also switch your battery out with a deep cycle battery
I'll look into this option, especially as winter comes along and I need headlights more often.
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
