Old 10-17-2013, 05:35 PM   #15 (permalink)
jedi_sol
jedi_sol's Avatar
2013 STi *SOLD* - '13 Subaru Impreza WRX STi
Subaru
Sports Cars
Team Turbocharged!
90 day: 26.59 mpg (US)
1996 Geo Metro *RETIRED from Ecomodding* - '96 Geo Metro Base
90 day: 58.68 mpg (US)
Originally Posted by darcane View Post
This would be a challenge, it is only an issue while driving and if I stop, I won't be able to start it with the key...
This wont be a challenge at all.
Assuming that the car is completely off. If you hook up a volt meter to the battery leads, you will still get a voltage.
12.7 volts = 100% charge
Therefore, assuming your battery is truly drained, if you hook up a volt meter to the battery with the car off, then your voltages will be something less than 12.7volts...maybe something along the lines of 12.0 volts.
See the rest of the Sti project log:
http://ecomodder.com/forum/showthrea...log-26612.html
