Old 10-18-2013, 05:25 PM   #32 (permalink)
H-Man
The brake pedal is evil
Denny's Detector - '08 Mercury Grand Marquis
Taserface - '17 Chevy Volt
An idea: Use an electronic gas pedal sender and open the throttle body to WOT at 6:1 CR before switching to 13:1 CR and shutting the throttle body to deliver the right power output. If it had continuously variable valve timing, it could be possible to cruise with the engine at WOT and the 6:1 CR setting and then gradually raise the CR to raise power output.
Getting sensor data off of a pre OBDII Toyota ECU via TDCL.
All of this is on E10: Project E is my current focus.
