Old 10-18-2013, 10:25 PM   #207 (permalink)
t vago
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Originally Posted by AndrzejM View Post
Josemapirio,
It seems that you've connected your cable not to the "ground" side of the injector but to the +12V side...
It's possible. Josemapirio, are you absolutely sure that your fuel injector sense wire is actually connected to a fuel injector driver wire? I verified that the Arduino Mega option does indeed work with PE4/PE5 (INT4/INT5).
After getting back home from Prague I can say that new code works very stable no issues at all. I was switching between screens a lot wanted to know better all new features.
That's wonderful to see. I'm glad that you saw no significant issues. I, of course, seem to see all sorts of defects in the code, every single time I operate my MPGuino. Perfectionist, perhaps...
It seems that I need to calibrate it again. I've entered values from previous version but it seems that calibration is off. I'm not sure because I haven't filled Berta's tank yet but it seems that way watching the needle and odo. I'll tell you more after filling up the tank.
You were mentioning something about the metric/fuel consumed bug, earlier in this thread. That could not have helped with earlier calibration.
The Following User Says Thank You to t vago For This Useful Post:
josemapiro (10-19-2013)
